oil in spark plug - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-18-2004, 07:39 PM   #1 (permalink)
View smuriukicat's Photo Gallery
oil in spark plug
hey cats,was changing my plugs on my turbo89 and noticed oil in two plug holes at the end. is this ablown head?
smuriukicat is offline   Reply With Quote
Old 12-18-2004, 09:03 PM   #2 (permalink)
5M-GE
repinS's Avatar
View repinS's Photo Gallery
Might be as minor as valve cover gaskets
Might be as major as piston rings
I doubt it's a blown head gasket. But that just might happen eventually.
85 Cressida // RIP 11/2003
95 Pontiac Bonneville SSEi | 3800 SC | 225hp/275lb-ft
repinS is offline   Reply With Quote
Old 12-19-2004, 12:32 AM   #3 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
When all eles fails, do a compression test. If you've got the plugs out, you've already done all the hard work...
Old 12-20-2004, 10:24 AM   #4 (permalink)
View FromDaStreetz's Photo Gallery
usually its just oil from a slow leak in the valve covers. The 3rd valve cover gasket (The center one that has the spark plug wire holes) Drys out quickly and doesn't keep out leaks anymore once its hardened up from the engine heat.
Red 89 Turbo HardTop
FromDaStreetz is offline   Reply With Quote
Old 12-20-2004, 11:35 PM   #5 (permalink)
View supraturbo1987's Photo Gallery
check the valve cover gaskets. That is a pretty safe bet.
trev87supraturbo
supraturbo1987 is offline   Reply With Quote
