'87 supra n/a automatic help!!!!
for some time i have had problems with my '87 supra n/a auto. i had a feeling that it was my spark plugs, wires, dist. cap & rotor and/or fuel injectors so i took it to my mechanic on monday for a diagnostic. they comfirmed my assumptions and said they will change all of the plugs, wires and dist. cap & rotor and also my #4 injector and new seals/o-rings. on tuesday, i pick the car up and i test drive it. while driving the car it would take a while to shift into gear then finally jumps into gear but won't then downshift. i tell the mechanic WTF. you guys had to take off the Throttle body and Intake manifold to get to my injectors so you must of touched the throttle cable, right? they test drive it, adjust the cable but it still doesn't run right. they said it might also be a bad tranny governor. please help!!! my tranny was shifting good before i dropped it off. it's almost thursday and i still haven't gotten my car back. do you guys think that they are just f--king with me or do you think something else is wrong?
