brick wall @6psi - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-03-2005, 11:48 PM   #1 (permalink)
View turbine1's Photo Gallery
brick wall @6psi
just upgraded the turbo and fuel system safcII and acv-r
when i boost i hit a fuel cut or somthing cuts off at 6 psi
turbine1 is offline   Reply With Quote
Old 01-04-2005, 01:54 AM   #2 (permalink)
4G63Attack's Avatar
View 4G63Attack's Photo Gallery
what are you modes?? is your car getting more air? bigger intake system ?
4G63Attack is offline   Reply With Quote
Old 01-04-2005, 02:21 AM   #3 (permalink)
Lexus AFM
550CC injectors
SAFC 2
Walbro Fuel pump
Aerospeed FPR
Old 01-04-2005, 11:58 AM   #4 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
Fuel cut throws a code. Have you polled the TCCS yet to find out what it says is happening?
Bob
Old 01-05-2005, 01:13 PM   #5 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Fuel cut never threw a code on my car. You hit it, slammed your head into the steering wheel, the CEL came on, then turned off. Didn't every actually throw a code.
In my personal opinion, you're either getting a lot more boost than your gauge says, or you've got a boost leak.
Old 01-05-2005, 01:18 PM   #6 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
what kind of supra is it a n/a model ???
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
Old 01-05-2005, 01:21 PM   #7 (permalink)
Got Hardass?
Jeeves's Avatar
Wraith, with those mod lists I'd definately say he's a Mk3 Supra w/a 60-1
(most likely) updgraded turbo.
Old 01-05-2005, 05:39 PM   #8 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
I meant is it on n/a electronics...
MySpace:
Old 01-08-2005, 03:47 PM   #9 (permalink)
View teamols's Photo Gallery
connect fuel pressure guage and make sure you are losing either pressure or injector control
teamols is offline   Reply With Quote
Old 01-08-2005, 05:35 PM   #10 (permalink)
Got Hardass?
Jeeves's Avatar
Umm, no. It's more likely to be a boost leak. He should check stuff that doesn't involve buying gauges and tools.
Old 01-09-2005, 02:38 AM   #11 (permalink)
View astralquestor's Photo Gallery
Don't forget the simple things. My 82 Supra kept starving to near stall. For the previous replacement of the insanely expensive and stupidly located fuel filter, I had, first, balanced the car at the centre and rocked it back and forth, sloshing the fuel to wash the sediment out the drain.
It seemed to soon to need to replace it again, so, item by item, I replaced everything but the tires and eventually discovered the ** fuel filter plugged again from the old tank's sediment.
Again, I replaced the insanely expensive and stupidly located fuel filter. Then, with some help, I installed an in-line fuel filter between the tank and the pump, where the idiots should have installed it at the factory. Since it is a large filter for my 1-ton, diesel cube van, I doubt I'll ever have to replace it again, or at least not for years.
Even then, it will be far cheaper and easier than the manufacturer-idiots meant it.
Check your fuel supply filter(s). before you make the same stupid mistake as mine, failing to check the basics.
astralquestor, rrw@connect2net.ca
Start 2005 Jan 09 Sun 00:00h prox
..PRJ\AUTO\TOYCS\2005\JAN\091A 2005 Jan 09 Sun 00:40h
astralquestor is offline   Reply With Quote
Old 01-09-2005, 03:07 AM   #12 (permalink)
Got Hardass?
Jeeves's Avatar
A low fuel cut is an indication of too much fuel however, not too little. A clogged fuel filter will give you a stuttering, hesitation feeling in these cars.
A Low fuel cut (which is what it is if it feels like it's hitting a brick wall) at the same place in boost everytime. This is either too much fuel, a boost leak, or the a Mass Air sensor failure.
Old 01-10-2005, 02:57 AM   #13 (permalink)
re: brick wall @6psi
My low-fuel problem from the clogged filter gave no indication at start-up, but, after varying times and distance, would become increasingly sluggish and slow to swearing, horn-blasting, tail-gater speeds, but no stuttering. The power would just fade away.
It would stall if I applied much accelerator.
It's still a good idea to check the basics before other, more expensive investigations. If the filter's not clogged, fine, go on to other basics and gradually work to more expensive possibilities.
Of course, some symptoms exclusively suggest eplicite solutions. Basic, investigative procedures are the alternative for uncertainties.
Start 2005 Jan 10 Mon 00:05h prox
..PRJ\AUTO\TOYCS\2005\JAN\101B 2005 Jan 10 Mon 00:53h
Old 01-10-2005, 11:45 AM   #14 (permalink)
Got Hardass?
Jeeves's Avatar
Maybe, but when the symptoms point to a SPECIFIC issue, isn't it smarter to see if he's suffering from that issue or should he make sure he's got adequate tire pressure while he's at it?
Fuel cut is not caused by a clogged filter. He can check it. But his symptoms don't match that at all.
Old 01-10-2005, 03:54 PM   #15 (permalink)
View damone's Photo Gallery
LOL
I think it sounds like a bad boost leak
damone is offline   Reply With Quote
