Shimming the waste gate - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-08-2005, 03:40 PM   #1 (permalink)
View Knot Yew's Photo Gallery
Canada Shimming the waste gate
Have any of the club members shimmed the waste gate to increace the boost ,, if so what was the result of their efforts,, it seems such an easy upgrade 4- 3/8 washers ,, I am interested in your comments.. Regards Knot Yew
Knot Yew is offline   Reply With Quote
Old 01-08-2005, 03:43 PM   #2 (permalink)
View teamols's Photo Gallery
internal or external wastegate, boost controllers used are cheap
teamols is offline   Reply With Quote
Old 01-08-2005, 03:48 PM   #3 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
Yep. It works. Not the prettiest method, but effective. You may have to try a couple of times to get it right, and I wouldn't head beyond 10psi with them (boost creep gets worse the more you shim...the door stops being able to open properly).
Also on the cheap, you could also look to ball and spring boost controllers similar to the dawesdevices.com one...should cost little more than $20-50, and have some advantages to the shimming method when getting pressures higher.
