2JZ-GTE in SC300... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-09-2002, 07:30 PM   #1 (permalink)
I has boost..!
Razo-E's Avatar
View Razo-E's Photo Gallery
hey guys, i asked this in the Lexus forum, and i got help, but the estimates were little too expensive...so how much does it take to implant a 2JZ-GTE into a Lexus SC300? with parts, labor, and all of the necessary things that go along with a project like this...i want to get an estimate from a couple of people so i can make an estimate...
1986.5 5-speed '91 7MGE
1989 5-speed TURBO Targa (NA->7MGTE) BPU and lots of rare/JDM/Euro stuff
1992 5-speed hardtop - 2JZ-GE
2005 Scion xB - no longer stock
Razo-E is offline   Reply With Quote
Old 07-16-2002, 10:28 AM   #2 (permalink)
Turbo-Yota power
Jzs147-RR's Avatar
View Jzs147-RR's Photo Gallery
So far the swap on my GS300 where somewhere in the 10000-15000 just in parts and estimated labor since I did all my own.If you do all the work yourself it should cost you 6000$ if you stick with your stock tranny and 10 000$ if you go for a Getrag.Remember there are alot of things you need to do to get this engine running and you loose some features like trac and cruise unless you realy want to make them work.All in US $$ btw ..
_________________
Engine is running psoosh pshoosh ..
Going to have alot of work done before I actualy get this car moving
http://www.my-camry.cityslide.com
<font size=-1>[ This Message was edited by: Jzs147-RR on 2002-07-16 11:28 ]</font>
Jzs147-RR is offline   Reply With Quote
Old 07-16-2002, 02:40 PM   #3 (permalink)
Bone Stock :(
View TRD2000GT's Photo Gallery
There's an RX-Y with A supra engine in it pulling over 800HP at the wheels...Supra 7
'91 T
My Site
TRD2000GT is offline   Reply With Quote
Old 08-18-2002, 12:00 AM   #4 (permalink)
View majicmeow's Photo Gallery
the SC300 already has a 2JZ-GE in it... why not just put a turbo setup on it insted of doing a swap??
"Technology is the only substitute for cubic inches"™
majicmeow is offline   Reply With Quote
Old 08-21-2002, 06:32 PM   #5 (permalink)
Turbo-Yota power
Jzs147-RR's Avatar
Some people have done some nice things to the 2jzge but I think just thinking about Twins is what gets most people to go with the GTE.For street use your much better with a GE since it develops nice power with a good turbo system and has more Torque down low compared to a GTE ,only problem is you will probably see 800hp max out of this engine on race fuel.GTE vs Ge I say for street use and no race gas the GE is a better choice but for racing power the GTE is king.
5sfe powered turd ...
Old 08-25-2002, 10:43 PM   #6 (permalink)
the GE also runs a little higher compression than the GTE, which helps the tourqe. Otherwise, they are identical. You can push just as much horsepower out of a GE as a GTE, you just have to be careful when you tune it.
Old 08-27-2002, 04:27 PM   #7 (permalink)
and...
The GE also runs a different throttle body... kinda crapy if you want to run turbos I guess =) easily changed though
