No Heat In My '89! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-30-2005, 03:10 PM   #1 (permalink)
View suprasweetie's Photo Gallery
No Heat In My '89!
I've Had My Supra For About 5 Months Now And All Has Been Well Until About A Week Ago When My Heat Just Stopped Working. I Was Driving To Pick Up My Boyfriend And My Car Was So Warm, I Turned It Off When I Got There Then When I Went To Turn It Back On I Got Nothing. You Can Kind Of Hear That The Vents Are Switching From, Like, Defrost To Full Heat, But No Air Comes Out. Someone Help!
suprasweetie is offline   Reply With Quote
Old 01-30-2005, 09:20 PM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
No hot air or or just cold air? If it's just not getting hot air, I suspect your Heater VSV has failed. This is easy to replace/fix. Just say which problem it is.
Old 02-03-2005, 11:17 PM   #3 (permalink)
Powered by Soundstream
View AMScamrySE's Photo Gallery
Maybe check your thermostat too. Not too sure.
AMScamrySE is offline   Reply With Quote
Old 02-03-2005, 11:29 PM   #4 (permalink)
Got Hardass?
Jeeves's Avatar
Nah, this is a known issue with Supras. 99% guarenteed not to be thermostat, it'd show up in other ways.
Old 02-04-2005, 02:37 PM   #5 (permalink)
View busybeezturbo's Photo Gallery
Maby the vaccume line to the VSV has become cracked or come off.located passenger side upper fire wall.
busybeezturbo is offline   Reply With Quote
Old 02-05-2005, 01:41 AM   #6 (permalink)
View damone's Photo Gallery
It sounds to me as if No air is coming out at all.. Which if that is the case, the heater VSV is not the culprit..
The things ide check are
1. a blown fuse or circuit breaker
2. bad heater relay
3. bad wiring or loose connection
4. a bad blower motor
damone is offline   Reply With Quote
Old 02-13-2005, 11:14 PM   #7 (permalink)
REACHING FOR 11'S
View 91gredsupra's Photo Gallery
if you can get cold air and not hot your blend door is probally stuck
91gredsupra is offline   Reply With Quote
Old 02-14-2005, 12:43 AM   #8 (permalink)
real men slide sideways!
View supranerd1987's Photo Gallery
wheres the blend door located at...and is it easy to get to?
supranerd1987 is offline   Reply With Quote
