Originally Posted by repinS
As in not machining the block? And using a metal gasket?
Countdown to next BHG: commence.
If you're going to MHG, you'll have to mill the block too.
Phucking W3rd.
Tools:
19mm 12pt Socket 1/2"
17mm 12pt Socket 1/2" & 3/8"
14mm 12pt Socket 3/8"
12mm 12pt Socket 3/8"
10mm 12pt Socket 3/8" & 1/4"
8mm 12pt Socket 3/8" & 1/4"
2 - 3" 3/8" Extensions
1 - 6" 3/8" Extension
1 - 3/8" Universal/Knuckle Joint
1 - Deep Well 14mm (REQ'd for ARP Head Studs on the 7M IIRC)
1 - Deep Well 12mm Generally handy
1 - Torque Wrench (good to 150ft-lbs typ.)
1 - Copy of TSRM Head Removal/Installation Proceedures (sp?)
Pairs of needle nose pliars, and general pliars..
20lb sledgehammer
Lots of rags...
/other assorted sockets depending on who/where your car's been worked on you'll probably even find an SAE bolt or two in there.
I'm sure there's more...
