MK3 supra questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-24-2005, 10:37 AM   #1 (permalink)
View dsmkiller's Photo Gallery
MK3 supra questions
New here and im looking to buy a mk3 supra. just curious if there is anything i should look for in particular any commen problems with them or anything along those lines.
Thanks
dsmkiller is offline   Reply With Quote
Old 02-24-2005, 06:09 PM   #2 (permalink)
5M-GE
repinS's Avatar
View repinS's Photo Gallery
head gasket head gasket head gasket
search search search
85 Cressida // RIP 11/2003
95 Pontiac Bonneville SSEi | 3800 SC | 225hp/275lb-ft
repinS is offline   Reply With Quote
Old 02-24-2005, 06:56 PM   #3 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Repin, I see a trend. Are you trying to say something? Bwahhahaha
DSMKiller, I think the Head Gasket may be a weak point in the Mk3 Supra.
Old 02-24-2005, 10:28 PM   #4 (permalink)
thanks for the replies.
Old 02-25-2005, 11:27 AM   #5 (permalink)
88 Corolla 4door
View albertmdh's Photo Gallery
how can i tell about the head gasket when i go to look at a car? or is this where i pay some mechanic 20$ to check out the car for me? anyone know any good mechanics in the Fredericksburg VA area?
albertmdh is offline   Reply With Quote
Old 02-25-2005, 11:48 AM   #6 (permalink)
Got Hardass?
Jeeves's Avatar
Take a compression tester with you. Test cylinders #1 and #5. They're easy to get at without disturbing anything. If they'll allow you, compression test it.
If not, check the coolant, see if you can see a rainbow in the top of the radior neck. If so, that's often a sign of coolant in the oil. A common sign of a blown headgasket. If you can, drive it long enough to get hot, take it for a short jaunt down the freeway. See if the temp gauge does anything funny. Obviously, if the car smokes white (after it's warmed up), that's a bad sign. And generally, ask if anythings been done to the car, dig into it's maintenance history some.
Old 02-25-2005, 02:39 PM   #7 (permalink)
88 Corolla 4door
ive been trying, but the owners havnt had it for long, bought it off of ebay from new york, then the guys company gave him a car, so he's selling this one, so they dont know much, and i dont have a credit card to carfax. lame.
Old 02-25-2005, 03:30 PM   #8 (permalink)
Got Hardass?
Jeeves's Avatar
Hmm, then just start checkin' it out. Also look for spots in the driveway where it's parked. This is often an easy trick to see if it's been leaking or anything. Other than that, just investigate it as much as you can.
Old 02-25-2005, 03:39 PM   #9 (permalink)
88 Corolla 4door
yeah, im on it, i want it really bad, test drive was all it took.
Old 03-01-2005, 12:36 PM   #10 (permalink)
View jsbenami's Photo Gallery
Give me the VIN I have an unlimited number of uses for carfax for the next few weeks. I bought an account a couple of weeks ago when I got my MKIII. I'll run it and send it to you somehow. But don't put too much faith in carfax. One car that showed up clean, I went out to Kansas city to see and it had been is a mega wreck, and had its frame pullled...luckily I knew what to look for
jsbenami is offline   Reply With Quote
Old 03-01-2005, 01:27 PM   #11 (permalink)
View MANAML's Photo Gallery
hi all I too am new,I finnally had time to post and say hi.My name is Mark and I live in Arizona.I bought a 87 non turbo a couple weeks back and love it.I was having some overheating and losing coolent problems and just started replacing things starting with the cheep stuff first( such as theromostat and hoses ) hoping it was a BHG but it turned out to be a plugged radiator.there is a few other things I need to do to it ,like ball joints,tune up,and other minor things.I got a real good deal on it $1200.I am still learning aboout the supra.So I hope that if I have any questions someone will be willing to help me out.
I too am not able to do the carfax thing cause no card .I did the free thing and it said it has 6 lists.so jsbenami is there any chance you would be intrested in helping me out too? I would be extreamly greatful.
I also have a question does anyone know how much power the autos can handle.I am forced to use the auto trans since I am paralyzed.
Thanks for any and all help.
Mark
MANAML is offline   Reply With Quote
Old 03-01-2005, 02:20 PM   #12 (permalink)
Turbos = Witchcraft
Ne0z31's Avatar
View Ne0z31's Photo Gallery
i dont feel like reading up on this post, so ill just say a few things... first off... eVERYTHING can be replaced for relatively cheap on this car except one thing... the body, make sure there is no rust on the undercarriage, open the hatch and open the side compartments and look inside to see if there is rust inside the wheel well area, check underneath the doors and try and notice how warped the sidemoulding is... if its warped chances are there will eventually be rust
Ne0z31 is offline   Reply With Quote
Old 03-02-2005, 01:30 AM   #13 (permalink)
Got Hardass?
Jeeves's Avatar
Not quite.
Try tracking down a new-ish 87-88 Wiring harness for cheap or several other pieces.
Old 03-02-2005, 12:33 PM   #14 (permalink)
88 Corolla 4door
I got the carfax, 100% clean, 3 previous owners, no wrecks. Mechanic looked at it yesterday, says its in great shape, looks like ill have a 87 turbo next week for 1900.
