Rear Lights Go Out - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-01-2005, 05:24 PM   #1 (permalink)
View pikasupra's Photo Gallery
Question Rear Lights Go Out
Hello everyone. I'm helping my neighbor w/ her 87 supra turbo (7M-GTE) MA-07
When the lights are on, and you press the brake pedal the rear lights TURN OFF.
Any advice , much appreciated !
Also, how do you check for computer codes?
and any links to UNDERSTAND this beautiful beast would be kool.
Thanx
pikasupra is offline   Reply With Quote
Old 03-01-2005, 05:28 PM   #2 (permalink)
5M-GE
repinS's Avatar
View repinS's Photo Gallery
I'd say that your brake lightbulb(s) are burnt out. It's a dual-filament bulb. Your parking lights are functioning fine, but the other filament - the brake light - is probably dead and gone. If this is the case, the symptoms would be exactly what you're describing.
85 Cressida // RIP 11/2003
95 Pontiac Bonneville SSEi | 3800 SC | 225hp/275lb-ft
repinS is offline   Reply With Quote
Old 03-01-2005, 05:50 PM   #3 (permalink)
View karugs's Photo Gallery
The bulbs are obviously working. The grounding wire has been switched to the wrong side.
Are you sure you're referring to a beautiful beast, not a beautiful neighbor?
karugs is offline   Reply With Quote
Old 03-01-2005, 06:11 PM   #4 (permalink)
5M-GE
repinS's Avatar
The parking lights, yes, but the brake light filament could be toast.
Old 03-01-2005, 06:37 PM   #5 (permalink)
both be beautiful !
Hey I replaced all 4 double filament (tail/brake light) bulbs and interestingly I have the same problem, but the furthermost brake/taillight bulb(pass side) is brighter than the other 3, and the other 3 are dim.
So when u turn on the lights, 3 bulbs are dim, 1 is bright, THEN when u press the brake the 3 dim bulbs go out and the bright one stays on and works fine !!
Sheesh - go figure !
Any help much appreciated
Old 03-01-2005, 06:51 PM   #6 (permalink)
5M-GE
repinS's Avatar
In *that* case, yeah, it may be the ground(s).
Old 03-01-2005, 07:31 PM   #7 (permalink)
wrong side of what? can u elaborate !
Thanx !
Old 03-01-2005, 08:19 PM   #8 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
Poor ground.
CraigW is offline   Reply With Quote
Old 03-01-2005, 09:58 PM   #9 (permalink)
Turbos = Witchcraft
Ne0z31's Avatar
View Ne0z31's Photo Gallery
a girl with a mkiii? you live where?? lol
Ne0z31 is offline   Reply With Quote
Old 03-01-2005, 11:38 PM   #10 (permalink)
san clemente, south orange county/ aw the girls here !
Anyway, I tightened the ground screws on the individual sockets and also tightened the bolt that holds that little yellow box under the driverside rear light assembly, to the body,
and now the drive side lights are working like they should.
but,one of the the passenger side tail/brake light bulb still goes out when you press the brakes.
what is that little yellow box under the driverside rear light assembly?
Thanx for the help
Old 03-02-2005, 01:33 AM   #11 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
I had this issue. Cleaning all the contacts, and tighting all the connections did wonders for me.
