Gathering Computer codes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-05-2005, 04:52 AM   #1 (permalink)
View jsbenami's Photo Gallery
3rd Generation Gathering Computer codes
Deos anyone on here know how to harvest computer error codes from a 7MGTE? Thanks.
jsbenami is offline   Reply With Quote
Old 03-05-2005, 07:31 AM   #2 (permalink)
Turbos = Witchcraft
Ne0z31's Avatar
View Ne0z31's Photo Gallery
take some fertilizer... put down some seed... wait a while for it to grow... once it does you will then be able to harvest
Ne0z31 is offline   Reply With Quote
Old 03-05-2005, 09:57 AM   #3 (permalink)
View Corollaized's Photo Gallery
3rd Generation codes
you use a wire to jump t and e3 on the terminal in diagnostic box located in engine bay. Turn the key to ignition. Count the flashes from the engine light.
example:
flash flash...flash flash flash shows code 23
flash ...flash fllash.............flash flash...flash flash flash shows codes 12 & 23
Corollaized is offline   Reply With Quote
Old 03-06-2005, 12:32 AM   #4 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Complete Check Engine Light Code List.
Straight from the TSRM.
Old 03-16-2005, 04:26 PM   #5 (permalink)
Hey, after finally getting around to aquiring a paper clip, I have an error "51" coming from my check engine light when I jump the E1&TE1 terminals. So deos this mean I need to replace my TPS sensor? The car has a hight idle at about 900-1400, it varies though usually its just 1100 most of the time.
51:
Diagnosis
* No "IDL" signal, "NSW" signal or "A/C" signal to ECU, during diagnosis check.
Trouble Area
* A/C switch circuit
* A/C switch
* A/C amplifier
* Throttle position sensor circuit
* ECU
Old 03-17-2005, 01:18 PM   #6 (permalink)
Got Hardass?
Jeeves's Avatar
I'd try calibrating it first and following the TSRM specs for checking to see if it's functioning correctly.
