Originally Posted by ahmedootie
i bought naturally aspirated cams, a lexus afm, a manual boost controller, and im lookin at 550 cc injectors. so i figured, i'd put this motor bac 2gether and not do n e thing crazy 2 it..just drive it till june...where i will b gone for a month, so tha car can hav its down time...u guys think it'll last till june? i wont up tha boost, but i do hav a heavy foot. as for tha new motor...i'm looking for opinions...i'm going to stick with tha 7mgte for sure, no 1j or 2j...those r too expensive...so ima stick wit tha 7m, but i wana build my own...new pistons, crank, rods, lifters rollers cams EVERYTHING new and after market...n e ideas on that? where i can get tha best parts for cheap? and then...does n e one hav a 7mgte block and head? separate is fine cus ima tear it all up n e ways. ur replies are greatly appreciated
peace
1) For future reference, please spell correctly. Posting like that really made me not want to read, reply, or decipher it.
2) The only cam from an NA that's different is the Exhaust cam, IIRC. The intake cam is the same.
3) There's really no telling whether a car will last or not. I've seen Mk3's rodknock and explode in the same day and I've seen 'em rodknock and drive for 3 months, then explode. Same thing goes for any critical part, Piston components, Head Gasket, Turbo Seals, Rod Knock, etc. There's no real good way to tell.
4) There aren't Lifters or Roller Cams for the Supra. The Supra uses a bucket and shim camshaft design, they aren't hydraulic. Hence, Supras will never have Lifter Tick.
5) Everything aftermarket for this car will cost you a pretty penny. Cams aren't commonly used nor are they extremely useful. They'll move the powerband around a little but I've never seen 'em do anything amazing. Pistons are useful as ours like to melt after 450hp. Rods are not necessary at all. The stock rods have proven to sustain more than 700hp w/o needing to be replaced. However, let me give you an idea of what you'll be looking to spend:
[Prices NEW from 935Motorsports.com, for a car looking to make 400hp-ish]
Greddy Intercooler Kit 87-92 Supra 7MGTE [Incl. HardPipes] -
$1,550.00
935 Street Upgrade Kit 87-92 Supra [No Manifold Replacement] -
$1,799.00
Walbro 255HP Fuel Pump -
$105.00
Aeromotive FPR MA70 Plug and Play Kit -
$289.00
Greddy Fuel Injector 550cc - $107.00/apiece x 6 =
$642
TED Upgrade Camshaft 7MG Pair [Since you wanted Cams] -
$1,300.00
Typical Motor Build (Labor) -
$1,500.00
Typical Head Work (Labor) -
$300.00
Crower Forged Piston Kit 7MGTE .020" -
$740.00
Cometic Steel Head Gasket 7M 86MM 2MM -
$169.00
ARP Head Studs 5M/7M -
$105.00
SPEC Clutch Stage 2 7MGTE [460ft-lbs, pushing it] -
$449.00
Koyo Aluminum Radiator JZA70 Supra [gotta keep cool] -
$385.00
3" downpipe with divorced wastegate [BecauseICan] -
$350
Tanabe Hyper Medallion Exhaust 87-92 Supra -
$499.00
935 Motorsports High Flow Cat 7MGTE -
$149.00
K&N FIPK Intake 87-92 Supra Turbo -
$139.00
Toyota Supra HKS SSQV BOV Budget Kit -
$250.00
APEXI SAFC2 AIR FUEL Controller [ebay] -
$239.99
Greddy Profec B Spec 2 Electronic Boost Controller -
$315.00
Full Auto Turbo Timer Black -
$74.20
52MM Electric Boost Gauge Black -
$118.50
-----------------TOTAL-= $11,586.19-------
(I think I hit a key wrong at the end, may be off ~$100, too lazy to re-calc)
Now, that's
WITHOUT touching: Suspension, Tires/Wheels, Brakes, Interior, and any gauges except for the boost controller. On top of the above,
I would add:
Zt-2 Wideband O2 + LCD Display Bundle -
$399
Exhaust Gas Temperature Probe -
$43.50
Greddy Strut Bar 87-92 Supra Front -
$80.00
Rear Strut Bar 87-92 Supra -
$120.00
Eibach Pro Spring Kit 87-92 Supra -
$225.00
Bilstein Shocks 87-92 Supra Front Pair -
$185.00
Bilstein Shocks 87-92 Supra Rear Pair -
$185.00
Wheels (generic) -
$700
Tires 275/45/16-17 -
$550
-------Grand--TOTAL-= $14,073.69-------
I hope you've got deep pockets.
As for where to buy motors, use the search button, it's been posted about before.
