twin turbo engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-24-2005, 03:24 PM   #1 (permalink)
View drivinthasupra's Photo Gallery
twin turbo engine
is there a twin turbo engine that u can put in a 86.5 supra?
can the 1jzgte fit in it?
how much r they?
wats the horsepower? torque?
drivinthasupra is offline   Reply With Quote
Old 03-24-2005, 04:49 PM   #2 (permalink)
5M-GE
repinS's Avatar
View repinS's Photo Gallery
All the info you want can be found here
85 Cressida // RIP 11/2003
95 Pontiac Bonneville SSEi | 3800 SC | 225hp/275lb-ft
repinS is offline   Reply With Quote
Old 03-24-2005, 06:45 PM   #3 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
repinS.
Thank you good sir.
Old 03-29-2005, 12:33 AM   #4 (permalink)
i didnt really find anything that helped me......but thanks anyway
Old 03-29-2005, 05:14 PM   #5 (permalink)
Got Hardass?
Jeeves's Avatar
Then you didn't search hard enough.
In the short time I've been here, I've seen no less than 3 discussions on the 1jz.
Old 03-29-2005, 05:42 PM   #6 (permalink)
New Mk3 Owner
View MkIII_Driver's Photo Gallery
3rd Generation
YES ok the 1jz-gte can fit but so could a 4 banger with the right mods to the car. what im saying is Common man. look at the old posts ok.
MkIII_Driver is offline   Reply With Quote
Old 03-29-2005, 06:21 PM   #7 (permalink)
um ok.......how much is the 1jz?
Old 03-29-2005, 06:28 PM   #8 (permalink)
New Mk3 Owner
3rd Generation
Hit up ebay, or go to google or some search engine and look for 1jzgte front clips
i remember them being around 2500 w/o the cost to get it to you.
Old 03-30-2005, 03:51 PM   #9 (permalink)
well crap...is there a 7m-gtte?
how much hp and torque does a stock 7m-ge have @ the wheels?
Old 03-30-2005, 04:20 PM   #10 (permalink)
Got Hardass?
Jeeves's Avatar
$2,500 is just the start of a 1jz swap. Most people spend in excess of $4,000 - $5,500.
There was no official 7M-Gtte, some have done it, but IMHO there's not a good reason to.
N/A Specs:
Horsepower: 200@6200
Torque: 188
Weight: 3400-3600
Engine: 7M-GE 2954cc
Transmission: W58
Injector Size: 380cc
Spark Plugs: NGK BCPR5EP-11
Compression: 9.2:1
Cylinder Pressure: 156
Fuel Pressure: 33-40psi
Turbo Specs:
Horsepower: 230@5600 (232 89+ models)
Torque: 246 (256 89+ models)
Weight: 3600-3700
Engine: 7M-GTE 2954cc
Transmission: R154
Boost: 6.8psi (Autos run lower boost because the tranny doesn't put as much load on the motor -- more like around 4 - 4.5psi)
Turbo: Toyota CT-26
Spark Plugs: NGK BCPR6EP-N8
Injector Size: 440cc
Compression: 8.4:1
Cylinder Pressure: 142
Fuel Cutoff: 11.4-13.7psi
Intercooler Efficiency: 3psi drop@6.8psi
That's not at the wheels, or correcting for altitude. Expect about a 12% loss in the drivetrain.
Old 03-30-2005, 11:03 PM   #11 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
Plenty of good reasons to. I wouldn't be doing it now for nothing
Given a pair that flow the same as a single, the twins will always have faster spool. In physics terms, it is an advantage due to lower polar moment of inertia. The mass of the shaft and wheels of the pairs is smaller, and the mass is more closely centred around the axis of the shaft, thus for the same amount of exhaust energy, they can accelerate faster. The magnitude is between a few percent and near ten depending on the turbos compared. The single is granted more efficient at peak power, but gets the short end of the spool stick. All about where you want the power. I want grunt, so i went twins on the 7M.
Old 03-31-2005, 10:15 PM   #12 (permalink)
grunt?.....well which is less expensive?
off the topic.......is it possible to make the lights only come up a little bit....and if it is then how do i do it?
Old 04-01-2005, 08:25 AM   #13 (permalink)
bgrieger's Avatar
Single...by a long shot. If you see the price of a single kit, multiply by 2 and still add some for twins, forgetting the prep work.
Lights...pivot light controller. Made in Japan, but some shops have access to them. Otherwise, dial your headlights up a bit manually.
Old 04-01-2005, 02:56 PM   #14 (permalink)
Got Hardass?
Jeeves's Avatar
bgrieger, at the same times, there are reasons the most power is made on large singles.
But yes, Single is very definately cheaper. One turbo = Less stuff to buy.
Old 04-06-2005, 12:32 PM   #15 (permalink)
my friend made the lights come up a little bit but when i turned them on they went back to normal
