leakand stall problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2005, 06:13 AM   #1 (permalink)
View madmann29's Photo Gallery
Hi i have a 87 supra turbo and when i drive it sometimes when i push the clutch in at around 2000 RPMs or higher the RPMs go down and keep going until it stalls, i dunno whats wrong, i need help.
Also the back of my car in the hatch leaks really bad, and i took it to get the weather strip again but they said it was fine so they tightened the wing and the antenna and it helped a litle but still leaks a good amount, please help
Thanks
madmann29 is offline   Reply With Quote
Old 04-01-2005, 11:05 AM   #2 (permalink)
88 Corolla 4door
View albertmdh's Photo Gallery
i thinki have both of these problems too, to a lesser degree on the leaking, and i only stall when the engine is cold, after pushing the clutch after moderate to hard driving in 3rd gear.
albertmdh is offline   Reply With Quote
Old 04-01-2005, 11:16 AM   #3 (permalink)
yea once the engine warms up for a while its better with me 2, but the whole leaking problem i dont know how to fix
Old 04-01-2005, 12:17 PM   #4 (permalink)
New Mk3 Owner
View MkIII_Driver's Photo Gallery
USA
hey if u plan to keep you car running correct i would hope that you let your car almost fully warm up before even leaving the driveway. This is causing you car to stall and other not as notiable damage. On the leak thing check the glass that was my problem. other things to check would be rear lights etc. (where is the lek comming from general area?
MkIII_Driver is offline   Reply With Quote
Old 04-01-2005, 02:02 PM   #5 (permalink)
88 Corolla 4door
I actually havnt noticed a leak, but theres some nice rust holes in the spare tire compartment, so I assume there at least WAS a leak...
Old 04-01-2005, 02:54 PM   #6 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Many things cause that rear hatch leak.
Most common - Rear Hatch Seals
2nd Most Common - Seals around the rear tail-lights.
Replacing those seems to solve that. Also, it's been found that a nice bead of silicon caulk on the tail lights (allow it to dry) makes a very good seal as well.
Old 04-01-2005, 03:45 PM   #7 (permalink)
88 Corolla 4door
in my case, while it may be both, i noticed some serious condensation inside my tails this morning, so im betting on those definatly being an issue.
Old 04-02-2005, 04:31 PM   #8 (permalink)
yea i have condenstation in my taillights, but i took it to a place to get it sealed and they did tests and said it wasn't the sealing so they tightened my wing and antenna and it helped a little but it still leaks a lot. the leaking comes from the part of the hatch closest to u when u open it and comes out of the plastic cover that is in the trunk
Old 04-03-2005, 03:08 PM   #9 (permalink)
88 Corolla 4door
i have much more leakage coming in from the sunroof seals honesly, it comes through the roofing and drips down on the dash even.
Old 04-03-2005, 07:23 PM   #10 (permalink)
Got Hardass?
Jeeves's Avatar
Replacing the Targa seals (not cheap ) is the best option to solve this sadly.
