W58 Transmission Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-12-2005, 01:37 PM   #1 (permalink)
View Ahbustae86's Photo Gallery
I'm building a corolla and needed to beef up my drivetrain. I found a W58 transmission but it had a shiftstick that had it's shift knob threads stripped down to where it looks almost grinded down. It also has a missing "U" Joint. I found a 79-81 Celica/Supra because I needed the rearend, but I was wondering if the transion parts like the shift stick and "U" joint will bolt up to my W58 trans. I also have a couple more questions about the supra. My Question's are:
1. Can the shift stick from a 79-81 Celica/Supra W50 trans fit on the W58 trans?
2. Anyone Know of an aftermarket short throw shifter for the W58?
3. Will the "U" joint from the 79-81 Celica/ Supra W50 trans fit in the W58 spline?
4. Anyone know what the gear ratio is in the Celica/ Supra rear end?
Any help will be greatly appreciated. Thanks
Ahbustae86 is offline   Reply With Quote
Old 04-12-2005, 03:29 PM   #2 (permalink)
View FromDaStreetz's Photo Gallery
the w58 tranny is in all NA models of supra up to 92 I believe.
Red 89 Turbo HardTop
FromDaStreetz is offline   Reply With Quote
Old 04-12-2005, 05:50 PM   #3 (permalink)
5M-GE
repinS's Avatar
View repinS's Photo Gallery
And beyond. MKIV manual non-turbo and Lexus IS300 5-speed all use the W58.
As for the rear end ratio, I believe it varied between years. May be 3.73, 3.91, 4.10, I don't know.
85 Cressida // RIP 11/2003
95 Pontiac Bonneville SSEi | 3800 SC | 225hp/275lb-ft
repinS is offline   Reply With Quote
Old 04-12-2005, 06:49 PM   #4 (permalink)
I was on the Celicasupra site and they mentioned that the 79-81 had W50 transmissions which used a metal case and the internals were weaker than the W58. Thanks for the help guy's.
