82 supra wont rev - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2005, 02:46 PM   #1 (permalink)
View foxcougar460's Photo Gallery
82 supra wont rev
Hi, I just bought an 82 supra, the car will not rev past 4,000. If I try to give it any more than part throttle it falls on its face. I've replaced the coil, plugs, and wires. Any one have any suggestions???
foxcougar460 is offline   Reply With Quote
Old 04-27-2005, 10:03 PM   #2 (permalink)
Got Fatass?
View ahmedootie's Photo Gallery
i hav no clu about that car, but i can tell u my guy has an 87 celica with tha same problem...turns out theres this speed control box by tha throttle body, doesn't let him rev past 3 grand!
ahmedootie is offline   Reply With Quote
Old 04-28-2005, 10:32 AM   #3 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
4k Rev Limit? I think that's the MAF's "OMGWTF" alarm...
Old 05-03-2005, 12:20 PM   #4 (permalink)
brand new maf, still same problem
Old 05-03-2005, 07:11 PM   #5 (permalink)
Land of The Few.
dax115's Avatar
View dax115's Photo Gallery
You could check into a fuel filter maybe. Don't know much about the car. Could be getting enough fuel to take it that high and not enough to go any higher. Let me know what is wrong when you figure it out.
dax115 is offline   Reply With Quote
Old 05-03-2005, 08:15 PM   #6 (permalink)
Got Hardass?
Jeeves's Avatar
Fuel Filters won't cause an actual rev. limit, they'll cause sputtering and hesistation.
I just now now noticed you said 82, not 92. Whoops. My tip was for a mk3.
Old 05-03-2005, 09:59 PM   #7 (permalink)
Land of The Few.
dax115's Avatar
He said that at 4 grand it would just fall on it's face not hit a rev limiter.
Old 05-03-2005, 11:01 PM   #8 (permalink)
Got Fatass?
is there a weird box by tha throttle body? it could b that same control box on my guys celica.
Old 05-27-2005, 12:07 AM   #9 (permalink)
midwestmk2's Avatar
View midwestmk2's Photo Gallery
Have you checked the throttle position sensor yet?
midwestmk2 is offline   Reply With Quote
Old 05-27-2005, 07:49 AM   #10 (permalink)
Noob ??? Not on cars !!
mrnickleye's Avatar
View mrnickleye's Photo Gallery
Exhaust, fuel, rev limiters
A partially plugged exhaust can cause a limit in maximum RPMs and speed. In those early year Toyotas they used cat converters filled with coated BBs. When the cat started to break down, it let the BBs go into the muffler and plug it up. (Usually the cat did NOT plug up). Give the muffler a shake up/down to HEAR if there is any BBs in it. Replace cat and muffler. Also, an exhaust 'back-pressure' test can tell if there is restriction. Also, in a dark area, like the garage, or night time, look at the exhaust header pipe about 6" past manifold to see if it gets a cherry red glow when holding the throttle to that limit it quits increasing the RPMs. (Don't do this for more than a few seconds, as HEAT KILLS)...This glow is caused by hot exhaust gas being restricted. The thottle will not allow increased RPMs after a certain point due to this restriction.
4 years at the Toyota dealer in the 80s, I replaced a 100 or so exhaust systems, most under warranty because Toyota ended up allowing up to 100k on manifolds, cats, and mufflers.
A VERY dirty fuel filter WILL cause your RPM and SPEED limits, as it will only allow a certain amount of fuel to pass thru it. Are you revving it in park, at a stand still?? Or are you limited when driving ??? These older cars, unlike most of today's modern cars, did NOT have rev limiting.
My '89 has a speed limit of exactly 125mph, caused by the stock computer shutting down the fuel flow. Sneeky little Bast****.
mrnickleye is offline   Reply With Quote
Old 05-27-2005, 11:19 AM   #11 (permalink)
Got Hardass?
Jeeves's Avatar
The Mk3's don't have speed limiters. I've seen 143mph in one myself. They have rev limiters, but not speed.
Old 05-31-2005, 12:11 AM   #12 (permalink)
View superium's Photo Gallery
Did you reset your ecu after installing the afm and other parts? Disconnect your battery for 30 seconds and drive it around for 15 minutes or so. Sign up on the celicasupra.com forum for more help.
superium is offline   Reply With Quote
