Originally Posted by movingviolation
blocking your egr valve is really bad for the environment. there's threads about it, just do a search. I have a problem with my egr as well, & I have every intention of at least clearing out the built up carbon deposits in the tube that travels between the block & the valve. as soon as I have the cash, I'm buying a new valve & replacing my stock one. a properly working egr valve also has the added incentive of improved gas mileage. as far as I know, anyway - I could be wrong in anything I've stated.
Yes, all it does is take the exhaust gasses of the #6 cylinder and put them back into the intake. Please explain to me how disabling it is so horrific for the environment and how that affects your MPG.
I blocked the thing off, didn't notice a single change and didn't look back.
EGR Theory.
EGR serves one purpose and one purpose only. That purpose is to reduce Oxides of Nitrogen (NOx). Undernormal combustion, Nitrogen(N2)Oxygen (O2) in the air and Hydrocarbons (HC) in the fuel combind into water(H2O) Carbon dioxide (CO2) and the Nitrogen remains unchanged. Under very hot combustion temperatures, the Nitrogen reacts with the other two byproducts and forms Nitrogen oxide (NO). After being released into the atmosphere, it picks up another Oxygen and becomes Nitrogen dioxide (NO2). In the presence of sunlight,
it combines with other compounds like Hydrocarbons and forms Smog. Since exhaust gas is inert (very stable) it doesn’t burn again. So by being introduced into
the combustion chamber, it will lower combustion chamber temps enough so that
the Nitrogen doesn’t react with the other compounds and is passed unchanged out
the tailpipe thus not contributing to smog. Now, since exhaust gas doesn’t burn, it
doesn’t exactly help with combustion. At higher RPM’s, this really isn’t noticable,
but at idle, the reintroduction of exhaust gas will cause a very rough idle and can
cause stalling if to much is introduced into the combustion chamber.
That's the closest it gets to touching "really bad for the environment".
