Hey Vic,
Straight from the TSRM: No idea. Maximum warpage is listed as .0039, or .1mm, and the block maximum allowable warpage is .0020, or .05mm.
The TSRM actually does not have machining limits listed, perhaps because they would recommend replacement rather than machine work. Off the seat of my pants, knowing most people running larger than 2mm gaskets have problems, you probably have a full 1mm total allowable machining between the head and the block, given the stock gasket is supposed to be 1mm after compression.
I'll check my Haynes manual to see if it has anything listed, but they generally just copy the TSRM and such anyhow...
