1985 Supra - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-30-2005, 09:36 PM   #1 (permalink)
View tcongo's Photo Gallery
Question 1985 Supra
If not started for a hour the car will start for just about 10 seconds then quits won't start at all after that unless left alone. Has new fuel pump but the car has sat for about seven years any ideas?
tcongo is offline   Reply With Quote
Old 05-30-2005, 09:57 PM   #2 (permalink)
View *01 TRD Camry*'s Photo Gallery
Have u checked the oil, does it do any type of noise when it's on 4 those 10 sec's?Best bet take it to a trusted mechanic and have them open the block up and then start checkin everything pistons,rods, etc. etc.
*01 TRD Camry* is offline   Reply With Quote
Old 05-31-2005, 12:20 AM   #3 (permalink)
View superium's Photo Gallery
Actually sounds like a mix between a faulty fuel pump and low battery. If the car sat for 7 years I hope you drained the gas tank and put fresh premium gasoline in it. Im assuming you did since 85s had internal fuel pumps so you had to drop out the gas tank. Fuel filter should be changed as well and so should many gaskets be changed.
superium is offline   Reply With Quote
Old 05-31-2005, 12:55 AM   #4 (permalink)
Re 85 supra
Yes I put new fuel in it new fuel pump and filter too it I am sure this is some sorta of problem with a sensor that has gone awry it starts and runs fine for a few seconds and then just stops will not start again unless its left sitting for a while. When it does start it seems to rev at a high rpm. could this be a throttle sensor problem or something else in the ECU?
Old 05-31-2005, 03:41 PM   #5 (permalink)
5M-GE
repinS's Avatar
View repinS's Photo Gallery
Are you sure that's the *first* thing he should do?
85 Cressida // RIP 11/2003
95 Pontiac Bonneville SSEi | 3800 SC | 225hp/275lb-ft
repinS is offline   Reply With Quote
