head gasket replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-06-2005, 08:56 PM   #1 (permalink)
View tonym509's Photo Gallery
3rd Generation head gasket replacement
ok...on Friday I lost revs while driving home & thought I snapped the timing belt. I had it towed to the repair shop - thank God for AAA. The shop specializes in Toyotas & had 3 MK3 Supras being worked on at the time - a good sign. Today I was told I didn't snap the timing belt but actually found out the cam seals & cam sprokets weren't properly installed by the last person working on the car which inturn destroyed the cams. I was quoted $150 for used cams & sprockets + time & labor & gaskets to fix this problem..total $750. I figured since I'm having all this done why not do the head gasket while I'm at it & save the hassle & expense later. I was quoted another $150 for the gasket, installed. My question is...do I need to have the head machined before having it reinstalled with the new head gasket? There's a reputable machine shop that sells complete heads, ready to bolt in for $450 minus sprockets. Would I be better off with a complete head replacement? If I reuse the stock head what happens if it's not machined before a new head gasket is installed? Also, should I replace the head bolts? If so, what do you recommend? If I replace the head bolts with ARP head studs, can these be installed with the engine in the car? Should I also install new valve seals along with the new cam seals if reusing the stock head? I'm hearing that the head should be torqued down to 72lb-ft, is this correct? Factory specs say 55lb-ft. I've read on the forum to use only an OEM head gasket, is this right? I'm having the parts ordered as we speak & work is being done this week so I need help ASAP.
thanks...
tonym509 is offline   Reply With Quote
Old 06-06-2005, 09:37 PM   #2 (permalink)
Got Fatass?
View ahmedootie's Photo Gallery
OK...
You need the head checked if you are going to use an OEM gasket, only if you plan on using a Metal headgasket will you need the head machined. If you are going metal headgasket, remember, the block needs machining as well. you should definately replace the stock headbolts...never reuse them, and i would suggest ARP headbolts, they replace the stock ones w/o any modification, and you don't need to pull the motor.
ahmedootie is offline   Reply With Quote
Old 06-06-2005, 10:15 PM   #3 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
Agreed. A close inspection of the block should be done to ensure the new gasket will seat, and the head in my opinion should always go for a resurface regardless of the gasket chosen. The 55ft-lb has been proven wrong, and is accepted as the primary reason we blow the gaskets up in the first place.
If the whole motor is not going to be machined, forget the metal gasket.
bgrieger is online now   Reply With Quote
Old 06-08-2005, 06:29 AM   #4 (permalink)
5M-GE
repinS's Avatar
View repinS's Photo Gallery
Originally Posted by ahmedootie
OK...
I'd have the head machined regardless if going OEM.
85 Cressida // RIP 11/2003
95 Pontiac Bonneville SSEi | 3800 SC | 225hp/275lb-ft
repinS is offline   Reply With Quote
Old 06-08-2005, 11:07 AM   #5 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
+1. I would never replace a headgasket without machining the head. It can be done, if you haven't damaged the head. But it's a piece of mind really.
And always use ARP hardware. I prefer studs to bolts myself.
Old 01-24-2006, 04:12 PM   #6 (permalink)
View johnathan1's Photo Gallery
what is the benefit of using studs over bolts? Price difference, are studs harder to install? And hoe\w does the head get damaged??
johnathan1 is offline   Reply With Quote
Old 01-24-2006, 05:42 PM   #7 (permalink)
Got Hardass?
Jeeves's Avatar
Studs apply their pressure from the heat side, and push down. Bolts apply their pressure from the block side, and pull down. The end result really is the same though.
edit: Re-Reading this thread, I want to know how he was getting a reputable Mk3 shop to replace a head gasket for $150 installed. A Toyota new head gasket is near that price alone.
Old 01-24-2006, 07:38 PM   #8 (permalink)
5M-GE
repinS's Avatar
No kidding. Charge parts at cost, free labour? ha. You've have to be directly related to the person for them to do that
