MSD Ignition Box - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-09-2005, 10:28 PM   #1 (permalink)
Noob ??? Not on cars !!
mrnickleye's Avatar
View mrnickleye's Photo Gallery
MSD Ignition Box
Has anyone out there installed an MSD Ignition Box on their MKiii N/A???
I hooked one up 2 years ago. I had to use an adaptor for the Tach/injectors to function properly. It works by making the plugs fire 15x instead of once on each power stroke. It will insure that ALL the fuel is burned. I could not tell any improvement, but I did see my MPG increase by 4 on long trips (26 mpg).
I removed it after 1 year because the tach needle would jump around occasionally. I emailed back and forth with the manufacturer trying to figure a way to get it solved. No success.
Any comments??
mrnickleye is offline   Reply With Quote
Old 06-10-2005, 12:25 PM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Any comments??
No clue, however, I do know that the Mk3 Supra's power distribution system isn't in real need of replacing. Many people make enormous power on it, usually only replacing it when they go with a stand-alone or the like.
Have you checked your wiring connections?
Old 06-11-2005, 03:10 PM   #3 (permalink)
mrnickleye's Avatar
Yep, all wiring was checked several times. I'm just gonna leave it off. The car runs great with factory setup. I was just trying to get some 'cheap' power gains.
