7mgte coolant system - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-27-2005, 06:02 PM   #1 (permalink)
View bad7mgte's Photo Gallery
OK, I have a 91 7mgte with around 50,000 miles on the engine and about 110,000 on everything else. THREE TIMES NOW, I have to replace the 90 deg. rubber elbows that come out of the water pump and into the thermostat, and the elbow on the back of the block (that runs into it i guess?). This is really starting to piss me off. Anyone else had this happen to them, it's like my water pump is putting out way too much pressure in my coolant pipes.
After the first two times, I used a 3/4" ID copper elbow and two 1" rubber connector hoses to hook the copper elbow to the block and thermostat housing. ---->the 1" rubber elbow bottlenecked out and exploded the other day right when I pulled into the parking lot at work at 4:30am. What else can I do? Ithought about running a longer rubber coolant hose around my intake tube...i just cant figure it out.....
bad7mgte is offline   Reply With Quote
Old 06-27-2005, 06:43 PM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Get better pipes? I've never heard of this one before.
Old 06-27-2005, 06:52 PM   #3 (permalink)
it's got to be more than the pipes....it's the stock elbow directly out of the water pump. I was wondering maybe if a US water pump on a Japanese engine or vice versa would affect this problem (although I'm pretty sure that the imported engines come with water pumps on them already).
See, even your JDM engine came with a water pump on it.
Old 06-27-2005, 09:53 PM   #4 (permalink)
View bosco659's Photo Gallery
Maybe excessive cooling system pressure??? Try a new rad cap, other than that I would be sure to use OEM hoses.
Good luck.
2000 Supercharged 4Runner
'89 Supra Turbo with a "few" mods
bosco659 is offline   Reply With Quote
Old 06-27-2005, 10:27 PM   #5 (permalink)
Land of The Few.
dax115's Avatar
View dax115's Photo Gallery
[QUOTE=bosco659]Maybe excessive cooling system pressure???
Could be caused by a bad radiator cap.
287HP 444.4TQ
dax115 is offline   Reply With Quote
Old 06-27-2005, 10:33 PM   #6 (permalink)
Thx dax115, I corrected my post - I meant rad cap, not thermostat
Old 06-27-2005, 10:56 PM   #7 (permalink)
Land of The Few.
dax115's Avatar
Ah its cool.
287HP 444.4TQ
Old 06-28-2005, 05:57 PM   #8 (permalink)
Got Fatass?
View ahmedootie's Photo Gallery
thats not tha problem...im doin that rite now...im assumin try changin tha rad cap and c wut happens
ahmedootie is offline   Reply With Quote
