Help my computer!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2005, 05:17 PM   #1 (permalink)
Toyota Daddy
chinesemechanic's Avatar
View chinesemechanic's Photo Gallery
3rd Generation Help my computer!!
I recently did a motor swap on my 1990 supra. I put a motor from an 88 so i switched the wiring harnesses over. After I got everything together and went to fire it up, it wouldn't start. So I checked for spark, compression, fuel pressure, and checked the timing. It all looked good. Then I hooked up a noid light to see if the injectors were firing. Only 3 were. i checked my wire splices and they were all fine. Then I remembered that I had a Theft-Deterrant system on it and my friend said that he had a Mazda do the same thing. He said there was a way you had to re-boot the computer or something like cycle the key five times or something. If any of you guys know the procedure will you let me know? Thanks
chinesemechanic is offline   Reply With Quote
Old 06-29-2005, 10:30 PM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
On a Mk3 Supra it doesn't work that way. It kills the ignition. It would turn the key and act like the battery was dead.
The ECU in the Mk3 Supras pre-dates OBDII so there are no fancy key tricks like that in them. If you're only getting spark on three of them you've got a huge problem. Why? Because they're linked in packs of two's. If only 3 are REALLY firing, you've done fuckered your coil pack somehow.
Old 06-30-2005, 04:56 PM   #3 (permalink)
Toyota Daddy
Uh I dont have coil packs I have a distrubitor. and anyways i am getting spark on all plugs. i know they fire two injectors at a time but what is causing it? Is the ECU that is messed up or what?
Old 07-01-2005, 10:37 AM   #4 (permalink)
Got Hardass?
Jeeves's Avatar
Oh yeah, you funny NA boys.
Whoops, and now I'm retarded. I can't read. I swore you said Spark Plugs.
Can't be much help, sorry. My guess is that it's not ECU though.
Old 07-04-2005, 03:31 PM   #5 (permalink)
View FromDaStreetz's Photo Gallery
disconnect the alarm and eliminate that possibility.
Red 89 Turbo HardTop
FromDaStreetz is offline   Reply With Quote
Old 07-05-2005, 11:46 AM   #6 (permalink)
Got Hardass?
Jeeves's Avatar
You can't fully. It's built into the PCM and the door locks. The closest you can get is clipping some wires and even then it'll still be there.
Old 07-06-2005, 04:32 PM   #7 (permalink)
Ballin Out of Control
View Wreckless's Photo Gallery
Make sure you're using the right injectors, they changed the impedance around '88.5 in the NA's from low imp to high imp, make sure you're using the injectors from the 1990 motor that is native to your ECU.
1995 black/black SE Hardtop, USDM 2JZ-GTE/Getrag swap, singled, fuel, triple disc, Kaaz, brembos, sparcos, racelogic blah blah blah
1987 silver/grey - 7M-GTE *was* 399rwhp/428rwtq
1991 LS400 white/grey - ballin daily
1991 MR2 Turbo 5-spd (sold)
Wreckless is offline   Reply With Quote
