4g into a 3g - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-13-2005, 04:43 PM   #1 (permalink)
View 89Supraboi's Photo Gallery
4g into a 3g
uhh i wanna kno how hard it is to put 2jz-gte into a 87 supra is there alot of custom stuff or no? also i good place to get a deal on a 2jz-gte and tranny
I'm a Mitsu kid turning on mah love o well i'm getting a supra and i am gonna love it i think
89Supraboi is offline   Reply With Quote
Old 08-13-2005, 07:16 PM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
Even easier is the search key, as this is almost a daily question...
bgrieger is online now   Reply With Quote
Old 08-14-2005, 11:44 PM   #3 (permalink)
ok i looked idk if i used good key words but nothing came up could you just link me to a forum that tells me what has to be done to get swap down
Old 08-15-2005, 11:03 AM   #4 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
No, it's not "easy". You have to knock out the tranny tunnel to fit things, and you will also need an ecu, wiring harness, and a transmission. The R154 will not bolt up. Above all else, it's an expensive swap.
Old 08-16-2005, 11:31 PM   #5 (permalink)
ok thank you, i thought of a new idea and was wonder would it be hard to supercharge mah 87??
Old 08-17-2005, 09:05 AM   #6 (permalink)
Got Hardass?
Jeeves's Avatar
There is not a supercharger for the 7m, so yes, that would be more difficult. Besides, who likes the idea of having to buy a new pulley just to make more boost? ;-)
Turbocharger > Supercharer
Old 08-17-2005, 01:43 PM   #7 (permalink)
but supercharger gives you more toque and i think i found a way to make supercharging it fair easy, but i'm thinking supercharging it will make mah computer go insane or something no so good happen, but the final question i have at this point, are the injectors on the 7m-gte and 7m-ge the same and or close to the same, same goes for internals
Old 08-17-2005, 04:49 PM   #8 (permalink)
Got Hardass?
Jeeves's Avatar
They are not the same. Toyota used the 290cc yellow top injectors from 1986.5-1988 and used a 315cc lime-green top from 1989-1992. Factory Mk3 Turbos have 440cc injectors. On top of that, the ECU won't know what to do with boost. The block also has higher compression and lacks oil squirters which would be used to cool down the pistons in a forced induction motor.
Sure you can do it, but will it be as good as a $800 swapped JDM Turbo motor? No.
I made 315rwtq and 262rwhp on 9psi. Superchargers do have faster low-end torque, but the fact is, you can't easily supercharge a 7M. Besides that, the fact that it's not done would say that it's either 1) Not easy, or 2) Not as good as the turbocharger.
