1986.5 Tailights won't go off - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-13-2005, 09:47 PM   #1 (permalink)
View FirebirdCamaro's Photo Gallery
USA 1986.5 Tailights won't go off
I just bought a 1986.5 Supra with a 5 Speed, and I have two problems which I think are related. First off, the tailights wouldn't go off, so to save the battery, I have disconnected it until I can get it to the repair shop. Second, when I am running it, the warning light that shows the tailights on is always on. Anybody know what is going on here?
FirebirdCamaro is offline   Reply With Quote
Old 08-13-2005, 10:55 PM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
possibly the brake adjustment is off so the brake light switch is always pressed...perhaps the light warning indicator noticed one bulb is burnt out, or there is a short inthe sensor itself turning on the brake lights. Finally, the same warning light is used for the parking brake. That switch may be stuck.
Aint wiring a bitch...
bgrieger is online now   Reply With Quote
Old 08-14-2005, 08:53 AM   #3 (permalink)
View spfld_supra's Photo Gallery
Mine is an 87 and doin the same thing. Haven't noticed the lights on all the time but the warning light on the dash is always on. Odd thing is all the brake lights work as well as the tail and turn. Gonna have to do some diagn'. Will post any tips I find.
spfld_supra is offline   Reply With Quote
Old 08-18-2005, 02:16 PM   #4 (permalink)
go honduh
View hachirokusupra's Photo Gallery
try disconnecting the connectors on the back that connect to the lights.. that is held on to the white bulb holder.. and add dielectric grease .. worked for mine cuz ive been getting that dash light since i did my tail light conversion and now its fine.. also check if the screws that hold the light bulb down are tight
hachirokusupra is offline   Reply With Quote
Old 08-18-2005, 03:50 PM   #5 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
actually, I'm going to bet the "taillight out sensor" box is dead and causing the lights to run 24/7. If you pull the trim out of the trunk. It can be found behind the driver side paneling IIRC. It's a yellow box about the size of a pack of cigarettes.
Old 09-11-2005, 05:40 PM   #6 (permalink)
View txfishing's Photo Gallery
1986.5 Supra Tail Light Out Warning Light
I also have the problem with the Tail Light Out warning light staying on. All my lights are working aswell. Just bought the car last month and this is what I've done so far:
1. Replaced the Tail Light Failed Sensor - Didn't fix the problem.
2. Tried all new Brake light bulbs - Didn't fix the problem. Put the originals back in.
3. Previous owner had installed Trailer Light wiring for pulling a motorcycle trailer. I removed the Trailer Light wiring all together - Didn't fix the problem.
4. Inspected all brake light bulbs. They all seem to be original except for one. The one that is different works just fine.
I'm running out of ideas. Can anyone else proved some.
Thanks
Jorge Salazar
Houston, TX
txfishing is offline   Reply With Quote
Old 09-11-2005, 11:20 PM   #7 (permalink)
Talking 1986.5 Supra Tail Light Out Warning Light
///// U P D A T E for 1986.5 SUPRA Tail Light Failure Sensor /////
I reviewed my wiring diagram in my maintenance book and decided to cut the single Violet colored wire that comes out of the Tail Light Failure Sensor. This wire is responsible for illuminating my Tail Light Out warning on my dash. I then checked all my lights and they worked as they did before. So no more Tail Light Out warning light to annoy me.
In doing this I know I will not have that sensor to rely on for telling when I have a burned out tail light bulb. I personally feel that's no big deal. None of my other cars (00 Tundra and 99 Accord) have this feature either.
Jorge Salazar
Houston, TX
1986.5 Toyota Supra
Old 09-16-2005, 01:23 PM   #8 (permalink)
View suziesupra's Photo Gallery
3rd Generation 86/87 wiring probems
my 87 had that lit and I replaced the bulbs---all of em and jiggled all the wires--brakes worked. try this. on 86 and older find stop 15amp and remove it and 87to 92 remove 15amp efi fuse for 30 seconds. this stopped my problem.
oh yeah...does anyone know where the knock sensor(s) is/are for the 87 7mgte???
suziesupra is offline   Reply With Quote
