yet again....another problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-14-2005, 02:50 PM   #1 (permalink)
View madmann29's Photo Gallery
Angry yet again....another problem
Hey, i've got an 87 supra turbo, and i've had nothing but problems since i've had it. I've put about $3000 in replacement parts(may not seem like a lot to some, but i'm 17 so thats a lot for me) and it seems when i fix one thing another thing goes wrong. Now, when i drive the car and i "get on it" and the rpms get around 3000 or higher i just hear this whining noise and i have no idea what it is. Its not when the turbo kicks in that it whines either, its when the RPMs are at 3000 and above, yes the turbo spooling then, but i've also had the turbo spool at 2000 rpm and it doesn't whine, only when the rpm is 3000 and above. Please help!!!
madmann29 is offline   Reply With Quote
Old 08-15-2005, 07:49 AM   #2 (permalink)
lord lucan's Avatar
View lord lucan's Photo Gallery
Does it sound like its definately from the engine? have you tried pressing the clutch out or dropping it in to neutral if its auto and revving it to 3000 to see if it goes or comes back in? Could be a front of transmission noise.
i know what 205mph looks like and its pretty.
lord lucan is offline   Reply With Quote
Old 08-15-2005, 07:52 AM   #3 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
Sound similar to a problem I have, bu I don't think it the same for you. Mine is my power steering pump.
http://www.xclusive.bz
Old 08-15-2005, 09:43 AM   #4 (permalink)
lord lucan's Avatar
its not your girlfriend is it? mine whines when i drive fast.
Old 08-15-2005, 09:48 AM   #5 (permalink)
lord lucan's Avatar
failing that,take the aux drive belts off one at a time and try it (but not fot long as the waterpump wont be turning and she will boil up) to elliminate or prove water pump,power steering,air con,alternator...if it sounds like its the front of the engine without these connected then could even be something like a cambelt tensioner or idler bearing which you wouldnt want to ignore.
Old 08-15-2005, 11:06 AM   #6 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
My first turbo had a nicked fin on the intake side, wouldn't whine all the time but when I got on it and it got to really moving it'd make a helaciously funky noise. Other than that, you'll need to be a tad more specific. Can you hear it when just reving it? or does the motor have to be under a load?
Old 08-15-2005, 01:01 PM   #7 (permalink)
If i rev the engine standing still theres no noise, its only when i'm actually driving. And the sound is definently coming from the engine. My friend seems to think it could be the bearings in the turbo, i'm praying that its not but i dunno. I dont know how to be more specific, its kind of a high pitch whine/scratching sound, thats the best i can do.
Old 08-15-2005, 01:37 PM   #8 (permalink)
92 SUPRA!
View Supra KING's Photo Gallery
When you listen to the noise very closely and you are accelerating can you hear the noise from the rear of the car? I know on my car I used to hear a winding noise an it was the differential going bad.
Supra KING is offline   Reply With Quote
Old 08-15-2005, 01:37 PM   #9 (permalink)
OK i found a way to explain the sound coming from my engine.....It's like when you blow up a balloon and pinch the sides and the air comes out in that high pitch whine. Thats the best i can do. Thanks
Old 08-15-2005, 01:42 PM   #10 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
sounds like a belt screeching.. replace your belts, nothing big but either way Supras are not great cars for a first car. You should've started with a Corolla or Tercel if you wanted reliability.
Old 08-15-2005, 01:57 PM   #11 (permalink)
Got Hardass?
Jeeves's Avatar
But if it doesn't do it while revving, that doesn't indicate belts. He's saying it only occurs when under a load.
Now, thinking about things that only occur under a load, the turbo won't spool if you just rev the motor, have to load it up. I'm still thinking it's turbo related.
Old 08-15-2005, 02:28 PM   #12 (permalink)
My friend seems to think its turbo related too, which would suck because i can't afford a new turbo. I really hope its not though.
Old 08-15-2005, 04:46 PM   #13 (permalink)
92 SUPRA!
If your in need of a turbo my one friend has a CT 26 with only 30,000 miles on the turbo its a ball bearing j spec turbo. He only wants $300 for it. If you would be able to spend that I could give him a call for you.
Old 08-15-2005, 09:35 PM   #14 (permalink)
that turbo sounds very tempting, im taking it to my mechanic on thursday, and depending on what he says i'll get back to you about it
Old 08-19-2005, 11:36 AM   #15 (permalink)
So the mechanic said it could possibly need a new head gasket and that could be making the whining noise. I do not have the money to replace it so unfortuately i have to get rid of it . So I've decided to sell my car. The link to the post for information is below.....
http://toyotanation.com/forum/t93236.html
