The Walbro has to be strapped to the factory mount, and you'll have to drop the tank to install it. The 550's will be required to get proper fuel for more than 12psi. You'll also need a way to flow more air or a way to turn down those injectors before they flow TOO much fuel and cause cylinder wash.
As for the Knock sensors, if you've got one broken the car almost doesn't run, it'll pull timing like a bitch, run WAY rich, and IIRC it has a rev. limit at like 3,000.
