91 NA will not run - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-02-2005, 05:15 PM   #1 (permalink)
View jab1751's Photo Gallery
91 NA will not run
I just went to start the car today and it will not start it will fire but wont run I checked the fuel pump it is fine.HELP!!!!!!!!!!!!!!
jab1751 is offline   Reply With Quote
Old 10-02-2005, 05:30 PM   #2 (permalink)
5M-GE
repinS's Avatar
View repinS's Photo Gallery
Well, you've given us a million and one possibilities. You're going to have to rule out whether you're missing one (or more) of three things: air, fuel, or spark.
85 Cressida // RIP 11/2003
95 Pontiac Bonneville SSEi | 3800 SC | 225hp/275lb-ft
repinS is offline   Reply With Quote
Old 10-02-2005, 05:56 PM   #3 (permalink)
I think it is a fuel problem,i pulled 2 plugs they are not wet.Using the haynes manual i did fuel pump check,and checked ohm on cold start injector,I also checked ohm on air flow meter everthing looked good except between E2 and THA it says i should have between 2-3 K but i have nothing could air floe meter be the problem? If it were faulty would motor fire but not run?
Old 10-02-2005, 08:32 PM   #4 (permalink)
Offical TN Hillbilly
TcmaBoy's Avatar
View TcmaBoy's Photo Gallery
Yes. During start up the ECU provides a preset amount of fuel. After start up it will switch to the MAF. I learned that after a head gasket job on my truck. I wasted a whole afternoon checking cam timing, spark, fuel etc. before I found the loose connector. Talk about feeling like an ass.
TcmaBoy is offline   Reply With Quote
