Another one that has been asked several times lately:
Q: Can I use my steering wheel controls with a device such as the JL Cleansweep?
A: You can still use the cd/tuner controls however you must use an external volume knob because the headunit volume knob is set at a specific position when you run the software that "flattens" the response of the factory headunit and if you change this position at the headunit you can induce the "factory equalization" thereby negating the benefit of flattening the response.
