An aftermarket UCA will not improve on steering or wander so long as you have or will have your truck aligned properly. Problem with going up to around 3" of lift is you can only get the alignment specs so close to ideal, which of course results in road wander. At only 2" of lift you should be able to have your truck aligned properly without the need for them. Tire size and tread pattern do not effect your alignment but can effect road feel, most likely what you have noticed. Aftermarket UCA's will not change that.
