grounding wires and how to wire amp, subs, etc?
95 V6 LE ... Stock HU ...
ok so since im running my subs off my back speakers ....
ill have to :
1) Sound
splice into rear speakers with speaker wire -> run those into my hi/low stinger adapter (but where do i ground that little brown wire to? do i need to run a longer wire to connect it and ground it?) -> connect the rca's into the amp (where do i ground the rca's?)
2) Remote
remote wire from amp -> to switch -> wire from switch spliced into remote antennae wire (if i use the tape function after turning the radio on, will it shut off my amp?)
Can i run the remote wire on the same side as the power wire?
3) Power
Running my 8 gauge wire... from reading and looking, ive located 2 spots where i can go through the firewall w/o drilling new holes ... the passenger side and the wheel well of the driver side.
What carpet and panelling do i have to remove to get it through the passenger side?
If i go through the wheel well, where does it go inside? where will it feed into the engine bay?
4) Switch
How the hell do i take off the dummy plate so i can cut it and put my switch in it?
Does the switch need to be grounded?
5) Sub
How do i wire my sub to be bridged?
I think thats it... thanks guys!
