Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 07-08 Camry HID Hi Beams
View Single Post
Old 09-03-2007, 02:35 PM   #10 (permalink)
IPDaily
2003 Camry Speedster
View IPDaily's Photo Gallery
Gen5
Originally Posted by white3ch0c0late
Actually, it wouldn't. Because of the reflector housing, you would have light in all sorts of places where you don't want it, and little light where you actually do want it.
EDIT: Its the exact same reason you wouldn't put HIDs in low beam halogen housings. Light spreads all over the place, except for where you really need it. You have to remember-- halogen housings are designed for only around 800-900 lumens of light or so. So the light doesn't bounce around so much inside the reflectors and doesn't glare. But you stick a 3000+ lumen HID bulb in there, and the light bounces all over the damn place.
exactly... and for the same reason, you wouldn't put HID's in the foglights... they aren't designed for HID's, the light would be scattered, probably inferior to halogen, and you'd have tons of glare, probably blinding people... if you wanna upgrade the foglights, just throw in some 2500K nokya halogens and call it a day...
2003 Toyota Camry XLE V6, 18x7.5" ASA rims +40mm offset, Bridgestone Potenza Tires 225/45/18, H&R Sport Springs, TRD Exhaust/Strut Tower Brace/Rear Sway Bar, Wood Steering Wheel, 20% LLumar Tint
2007 Toyota Camry SE V6, Sport Leather
IPDaily is offline   Reply With Quote
