Originally Posted by geoff5093
Is the only reason because of the DRL's? It seems like it would be a good idea since HID's are alot brighter, they would light up the road and surrounding areas quite well. If you don't use your DRL's, would it still not be a good idea?
The reflection of the high beam is more upwards than to the sides. The low beam projects nicely to the sides. You can switch the DRL off and save the bulb and ballasts if you want them in the high beam. But it wouldn't do much really since the eye can only see so much and the halogen highs do a good job with the lighting output.
Originally Posted by white3ch0c0late
One other thing, you definitely didn't "search" hard enough, because I know that I have mentioned all this about HID fogs on several occasions on the forum.
Searching on a forum? Psh that is so last year.
