I've disconnected the cold start injector for testing purposes, because it operates only in the temperature range < 10 C. No, here is about 20 C. The There was no difference. The voltage is not checked, I must to find first: where is the cold start injector time switch mounted?
Here, You can find some pics of my engine. Check them out, and if You know, give me the names of the the designated parts.
http://www.thurzol.org.yu/~drdma/post-22-1062578765.jpg
http://www.thurzol.org.yu/~drdma/post-22-1062587517.jpg
http://www.thurzol.org.yu/~drdma/post-22-1062579070.jpg
http://www.thurzol.org.yu/~drdma/post-22-1062579001.jpg
http://www.thurzol.org.yu/~drdma/post-22-1062578903.jpg
My engine is for Switzerland (I think); there are no catalytic converter, no EGR and no fuel evaporative system. But this engine has T-VIS system, which is, when its closed, makes a knocking noise. It opens fully about 4000-5000 RPM. So, the actuator operates and the VSV is operating.
I'm not checked the fuel pressure for now. I'll also check the compression and the timing.
Any other hint?
