Originally Posted by yoshimitsu
hi guys.....im new on this forum...and baciscally i need some help with my corrola 4age....i am from south africa and some of cars are completely different....well i have a toyota corrola gli twincam 1988....my problem is that when my car is cold it would start but not easy....when i am driving the temperature gauge stays cold...but as soos as i hit traffic it goes up to half and then it will switch off and wont start....but if it cools down then it will.....also what i have seen when the car does want to start when it is cold or a little warm....a kick start will help and if it does take like that then i try starting it normal then it will start.....
guys i really need your help so if you it will be well appretiated....if you need more info i can send more....
Thanks
Did you get a "Check Engine light"?? If you do, I bet it is code #4!!! If so, change your coolant temperature sensor!!! I had the same problem!!! Good luck!!!
