Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - A/C Switches itself on
View Single Post
Old 09-05-2007, 12:53 PM   #7 (permalink)
TRD VVTi
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Gen5
Yep, when using the defrost the A/C compressor is engaged. Running the air across the evaporator will help remove moisture from the air being blown out. It's the same process that puts water on the ground when you run your A/C. When the air goes through the cooler evaporator the moisture in the air condenses on the evaporator's cooler surfaces as the air continues on to be blown onto your windshield and windows.
Now that you know nothing it wrong, you can trade it in on the Accord you want.
2006 Camry LE Special Edition
