Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - front abs engages when coming to stop
View Single Post
Old 09-08-2007, 12:20 PM   #7 (permalink)
hmthomas
View hmthomas's Photo Gallery
Originally Posted by Stillrunning
I think hoiskii has a valid solution. Certainly if the wheels are not able to stay in contact with the ground then they will not turn at the same rate and will trigger the ABS.
hmthomas, does this happen rough road or smooth road, slow or fast? I guess the other possibility since this just started after the axle install is that maybe one axle has incorrect # of splines. The sensor then would pick up what it considers different wheel speeds. I don't know if it's possible to mismatch axles this way??
it happens on smooth roads coming to a stop (maybe when it's going 2-7 mph) at a normal (non panic or hard stop) rate of braking. thanks for any input
hmthomas is offline   Reply With Quote
