I've done this many times
The corner light will come off. After you pull the two screws, it should pull straight forward about an inch or two and you should be able to piviot it out.
After you pull the corner light you will have access to the two nuts holding the light assembly in along with the bolt that holds the upper valance in place. While you are there you can use a needle nose pliers to remove the clip that holds the wiring harness from the corner light to the light assembly frame. You will need to pull the grille and the valance (which means pulling the other corner light) There are additional nuts holding the light assembly on near the radiator. You might have trouble getting your light out if you don't remove the plastic air dam/bottom flange off first (3 black phillips screws)
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
