Originally Posted by EverAE
essentially, but the pistons, rods, crank, yadda yadda will be all different, im assuming hes talking about a 4af block and putting a 4age head on (even if your rebuilding the bottom end for that matter)? youll still have to f- with the wiring, still have to do the EFI conversion, might as well do it reliabily with a swap, then a mutt engine thatll take just as much work.
nawww i was talking bout a 4af head on a 4age block...reason for doing so ppl say the 4age block is much stronger than the 4af block...and for future planing i did want to boost my 4af so i believe i wanted a better block after fixing the internals on the head u see...but i do see some ppl say that the blocks are the same but im just confused right now...and if i was planing to do a head swap i already know i should just swap the whole motor to save time and money as ppl will tell me too...but my goal is to tune up my 4af anyway possible...but if results are dissapointing...there is a 3sge motor at the junkyard waiting for me and reason why i did not say 3sgte is because someone already salvaged the turbo like everyone does in this town just to put in their sohc v-tec civics...sigh...well thank u for ur time yo...
