Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - turbo project
Thread: turbo project
View Single Post
Old 09-16-2003, 03:30 PM   #4 (permalink)
mr2freak
View mr2freak's Photo Gallery
it will fit since the 2.2 3s-fe is teh long stroke version of the 3sgte. wich means the cylinder diameter is the same, and everything is prettymuch the same
where you should be carefull is the compression ratio of the 3s-fe wich is higher than the 3sgte
and high compression ration+boost= disaster
just buy a 3sgte and crank the boost up till you have about 300 hp, then you can start tinking about spending some more money on boosting the engine
a 3sgte is worth about 1 300 cdn $
mr2freak is offline   Reply With Quote
