Originally Posted by Puffie40
On tuesday, my '95 Corolla's LH wheel started making a scraping noise when I would turn hard. When I checked it out, the top edge of the disc was getting a grooves scraped in somehow. I took the brake apart, but could not find anything wrong.
I did notice however, that the caliper could be wiggled around somewhat while bolted on. I'm not entirely sure it's suppossed to do that.
Other than that, I'm still scratching my head over this. Any Ideas?
It's probably not the pad bracket unless that part is obviously damaged.
Put the front end of the car up on jackstands and put it in drive and let the wheels idle around for a bit with the wheels off. My bet is you'll hear a constant whooshing sound meaning the caliper is sticking, which means the caliper needs to replaced.
