Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - HELP!! 92 4cyl wont start
View Single Post
Old 09-30-2007, 10:21 PM   #3 (permalink)
dc_98_cam
Originally Posted by Mjakaz95LE View Post
UPDATE!!
I went out and popped off the cap and turned it over and the rotor moves so at least not the timing belt. I then pulled out one of the wires and checked for spark and nothing! so i grabbed a new plug, plugged the wire into it and checked again and no spark on the plug..... so would this be the distributor or something else?
If this would be the distributor does anyone know of a place to get one? i mean i know toyota or pep boys but i wasnt sure if maybe our club had a discount place or just a good known place to get them.
If you can open the Ignition Section of the repair manual .... see sticky at top of page, there is a method to test the ignition coil, and also the pickup coil, using an ohmeter. .... If you find that one or the other is faulty, you could probably get a replacement at a salvage yard ... or probably a complete distributor .... just switch out the defective part.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
