Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - HELP!! 92 4cyl wont start
View Single Post
Old 10-01-2007, 06:31 AM   #6 (permalink)
dc_98_cam
... Not completely clear as to whether you have eliminated spark as the problem.
If you think fuel pump is possibility, the following are relevant.:
...check the 7.5 amp Ignition fuse. ... located in J/B no. 1 ...
under driver side dash panel.
...could also be the EFI Main Relay. Located in J/B no. 2 ... the fuse box under hood, to the right as you raise the hood.
...also, the Circuit Opening Relay controls the current going to the fuel pump. It is located in Relay Box no. 6, behind the glove compartment. ... You might be able to reach it from under the passenger side dash.
All of the above control power going to the fuel pump, as well as other factors, such as the ECU.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
