Newbi Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-03-2005, 09:25 PM   #1 (permalink)
View DR.2's Photo Gallery
Question Newbi Question
How do i install a boost controller and guage. ive searched this forum and google but i cant find how to. i sort of know how since my friends have any where from a VR-4 to a Turbo Stang. I am going to ask them to help but i rather do it my self. im tired of asking the same people. i feel nagging. any thing would help.
oh and how can i test my plug wires. i just put in a new cap and rotor and i want to check my plugs. the out side condition looks fine but what ohms or volts should they be at.
help is much appreciated.
-chad
DR.2 is offline   Reply With Quote
Old 10-03-2005, 09:51 PM   #2 (permalink)
FRANK THE TANK LIVES!
4DMR2t's Avatar
View 4DMR2t's Photo Gallery
Manual boost controller installation instructions:
http://www.twosrus.com/new/Lower_Fra...structions.PDF
Installing a mechanical boost gauge is easy.
1. Find a suitable location for your gauge.
2. Run a vacuum line from the gauge to a vacuum source off your intake manifold.
3. Splice the power wire to a power source that turns on with the gauge lights (I used the fog light switch).
4. Run the ground wire to a suitable ground location (a nut bolted to the chassis should do it).
And you're done!
"It's hard to drive at your limit, but it's harder to know where it is." -Sterling Moss
4DMR2t is offline   Reply With Quote
Old 10-03-2005, 09:55 PM   #3 (permalink)
Noob :-)
View ST185's Photo Gallery
Manual one?
http://twosrus.com/new/Lower_Frames/...icated/mbc.htm
Follow the link to the installation instruction.
Do more research on how the turbo/wastegate/boost controller works, and you won't have any more problem.
http://auto.howstuffworks.com/turbo.htm
http://www.streetracersonline.com/ar.../wastegate.php
and
http://www.boostcontroller.com/display_page.php?i=19
93 ST185
ST185 is offline   Reply With Quote
Old 10-03-2005, 09:56 PM   #4 (permalink)
Noob :-)
me ---> by Frank.
93 ST185
Old 10-03-2005, 10:10 PM   #5 (permalink)
thanks
Old 10-03-2005, 10:39 PM   #6 (permalink)
where can i find vacumm source for the line on the manifold?
Old 10-03-2005, 11:06 PM   #7 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
^ You can pretty much use any vacuum line. Either use the one coming off of your bypass valve... or the one leading from your intake plentum to the little black box that says "boost pressure sensor" in the rear of your engine bay.
Old 10-04-2005, 10:48 PM   #8 (permalink)
on this sensor it looks as though i have a little wire not hooked up. i asked around asnd people said thast not all wires have a place to go do to other models but that didnt make sense to me.?
