#sgte BEAMS -> Turbocharged? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2005, 08:23 AM   #1 (permalink)
View chrwof8217's Photo Gallery
I was curious what the reality of this dream might be. I want to try and find a BEAMS head for the 3sgte. This is the head that runs VVTI at around 200hp NA. The reason I want this head is because I want to keep my car streetable but have some extra power and something that no mr2 owner has done yet. I have seen a couple of mr2s with this motor in it, but not with forced induction. I do understand that engines with VVTI are much harder to manage as far as tuning, and an aftermarket management system will almost be a must. Anything else that comes to mind as far as the difficulties or hurdles in a turbo beams project, let me know. I am very interested in seeing how the mr2 community feels about this.
peace
chrwof8217 is offline   Reply With Quote
Old 10-07-2005, 09:34 AM   #2 (permalink)
Noob :-)
View ST185's Photo Gallery
I don't know the detail but it does exist.
93 ST185
ST185 is offline   Reply With Quote
Old 10-07-2005, 10:03 AM   #3 (permalink)
I know it exists in other cars, but I meant in an MR2. I can only imagine how much harder it would be to fit a larger head in the mr2, AND turbocharge it. Thnx for the info though, I appreciate it.
Old 10-07-2005, 11:23 AM   #4 (permalink)
Gameroom cash: $147537
Will it even bolt onto the 3S-GTE block? I guess its easier to find a complete engine and change the pistons and rods.
Old 10-07-2005, 12:23 PM   #5 (permalink)
Noob :-)
That was 3sge. So, turboing it would be interesting.
It got higher CR than 3sgte.
and the red top BEAMS came from MR2, so it shouldn't have problem with clearance on the top
93 ST185
Old 10-07-2005, 12:27 PM   #6 (permalink)
^That's why I say change the pistons, to lower CR. Better then try to see if the head will bolt on.
Old 10-07-2005, 12:47 PM   #7 (permalink)
A 3s is a 3s is a 3s. a 3sge head should bolt to any 3s short block. For turboing I agree the pistons should be changed, but since I already have a brand new 3s bottom end, i'd rather use it with the oil cooling and whatnot already on it for turboing. I wouldn't get pistons until I recieved the head and determined what the compression ratio would be with certain pistons. But that shouldn;t vary much from a standard 3sgte anyways. My two biggest concerns are 1: finding a blacktop beams with duel vvti (they never came with lift....sucks ass) and 2: will the vvti system hold up to the added pressure of pulling 400hp+ from a turbo? Thats the biggest issue. The reason hondas have such a hard time turboing is partly due to the insane tuning needed with v-tec, and i am sure toyotas aren;t much easier. A stand alone EMS should help out a lot, but I am not familiar with them. By the time I start this project I hope the new Megasquirt 3 will be out n about as I am familiar with it.
Peace
Old 10-07-2005, 12:48 PM   #8 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Will that head have adequet coolant ports to compensate for the higher temps created by turbocharging? just a thought
The Jedi Speeder at CarDomain
Old 10-07-2005, 03:51 PM   #9 (permalink)
Peace
Not saying you're wrong. It'll be easier to get the complete engine first then look for the block when the head doesn't fit. If you want lift, get 2ZZ-GE.
Megasquirt 3 able to control VVTi? Its not like Vtec which activate at a fixed rpm.
Old 10-07-2005, 04:04 PM   #10 (permalink)
The Other White Meat
terrastrife's Avatar
its far more reliable to get a beams 3sge and turbo that.
even with the higher all moter compression, the beams itself is better built and you can look at around 350hp befor eyou need to touch the internals.
and whats with all the questions about vvt(l)i and turbo? its electronic, it doesnt matter. dont touch the vvt(l)i tuning. strengthen the hardware.
blacktops come from caldinas
be careful buying a blacktop, some places will just get the valve cover and put it on a redtop motor, so youll have the little feed gaps in the cover but nothing for them to go to.
the black/red top scenario is confusing.. its possible to get single vvti on a blacktop from earliest model caldinas too, so be careful.
terrastrife is offline   Reply With Quote
Old 10-07-2005, 06:25 PM   #11 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I was hoping one of you guys could answer this question.. just for my own info and education
