I need some help with the 86 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2005, 11:16 PM   #1 (permalink)
View Kanesis's Photo Gallery
This is my first time on this forum im usally on honda forums. But i recently bought a 86 toyota MR2. Its good besides me needing to replace the oil pan gasket. This is my question, I was driving and i went over a speed bump really hard. The car then immediatly died. Ive tried to start it, it will turn over but wont idle. I checked the coil wire and the spark plugs idividually they all work. I have disconnected the fuel line from the fuel rail it spits out fuel when i turn it over. I poured fuel in the intake manifold and it would idle but when i pressed the gas it would immediatly die.I cant figure it out If anyone has had a similer problem on there mr2 please help me out i would really appreciatte your help. Im thinking fuel pressure regulator. But im use to hondas this has alot more vacum lines that i might not know about but ive checked all of them and there all hooked up so im stumbled.
Thank you
Kansesis
Kanesis is offline   Reply With Quote
Old 10-10-2005, 12:04 AM   #2 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
use Toyota seal packing (FIPG) for the oil pan. there wasn't a physical gasket for it.
check around your battery for the fusible link regarding your problem. also check fo rthe ballast resistor down around your coil/ignitor area.
ToyotaTechGeek is offline   Reply With Quote
Old 10-10-2005, 12:05 PM   #3 (permalink)
Ok i got it
When i went over the speed bump it made the middle connector on the ecu pull out. Not really noticeable but when i took off the ecu the plug came out further from me messing with it i plugged it back in and it works. Thank you for your prompt reply if that wasnt it im sure your suggestions would have worked.
Thank you,
Kanesis
Old 10-10-2005, 12:39 PM   #4 (permalink)
it's all good. i'm glad it wasn't anything substantially wrong!
