steering wheel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-11-2005, 07:17 PM   #1 (permalink)
View todd0305's Photo Gallery
steering wheel
Hey guys, I'm installing an aftermarket steering wheel on my 2. I have removed the steering wheel already but is stuck at the part of the column of that wheel thing where the airbag and the cruise controls is hooked to. Do I just cut the yellow wire that is suppose to hook up to the airbag? it's useless anyway because my airbag is not working. If you have detail steps or know where I can search that would be great. Thanks.
todd0305 is offline   Reply With Quote
Old 10-11-2005, 08:42 PM   #2 (permalink)
sargdesigns
arcasmachineracing's Avatar
View arcasmachineracing's Photo Gallery
If you don't intend on ever using the airbag again then you can just cut it.
Otherwise you can trace the wire back and disconnect it.
Don't forget to disconnect your battery before doing any of this! (duh)
Brandon
arcasmachineracing is offline   Reply With Quote
Old 10-11-2005, 09:18 PM   #3 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
PM me.... I've got some instructions if I can find them.
Old 10-11-2005, 10:05 PM   #4 (permalink)
Yes I did disconnect the battery arcasmachineracing. Thanks for the reminder though. One other question, what about the horn. I thought that there was suppose to be a metal surface that the aftermarket hub adapter grind on but there isn't one when I took out the column. I know that there is a harness that hooks up to the cruise control. Would that have the wires for the horn? If it does I can just tap it but not sure.
Old 10-12-2005, 01:27 PM   #5 (permalink)
Boosting 15 psi :)
View Drifting Dane's Photo Gallery
I might be interested in your stock steering wheel... what year/color is it? thanks.
Function over form.
Drifting Dane is offline   Reply With Quote
Old 10-12-2005, 09:49 PM   #6 (permalink)
Piddy's Avatar
^ I have a '91 Black Rubber laying around with the airbag laying around somewhere.
Old 10-13-2005, 12:50 AM   #7 (permalink)
Boosting 15 psi :)
If you happened to come accross it let me know.
Function over form.
Old 10-13-2005, 12:55 AM   #8 (permalink)
Piddy's Avatar
Long story.... but I might need some sort of cutting device.
http://www.highoctanenetworks.com/morepics/MVC-429F.JPG
You can have it as is.... I might need to get that thing off first though. This picture also doubles as a "clubs don't work at all" thread.
