Parking Brake ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-12-2005, 08:57 PM   #1 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Parking Brake ?
My parking brake handle has to almost reach the straight up position now for it to grab. can it be adjusted or is it just stretched out and need to be replaced? thanks guys
The Jedi Speeder at CarDomain
Old 10-12-2005, 09:50 PM   #2 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
Sounds like a bad ebrake cable. My deuce is the same way. Pull it STRAIT up... and it will barely hold the car. I almost lost the car once. I've adjusted mine a few times... just doesn't do the job. If I remember right you shouldn't leave it over winter with the ebrake up or it will help this problem develop sooner.
Old 10-12-2005, 09:54 PM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
OK, thanks. I guess I'll just replace it and not waste time trying to adjust it. it is 14 going on 15 yrs old. Thanks Russ
Old 10-13-2005, 01:13 AM   #4 (permalink)
View semi-charmed's Photo Gallery
yeah i had the same problem...replaced the cables and it worked fine...they're cheap enough anyway
semi-charmed is offline   Reply With Quote
Old 10-13-2005, 07:51 AM   #5 (permalink)
82toyo's Avatar
View 82toyo's Photo Gallery
The cable is easy to adjust. You just get under the car and there are 2 nuts you need to loosen and then adjust to where you need it and retighten them. It is easier than replacing the cable.
82toyo is offline   Reply With Quote
Old 10-13-2005, 11:58 AM   #6 (permalink)
View dsw20t's Photo Gallery
I have the same problem with my E-brake, not to mention that i live in hilly Duluth. I can only park in the backyard where it's semi-level... and every other blocks, following the sides of the hill. I'll try the cable adjustment first, then consider replacing it next. -Ferry
dsw20t is offline   Reply With Quote
Old 10-13-2005, 01:05 PM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
where are the nuts located...?
Old 10-13-2005, 03:24 PM   #8 (permalink)
FRANK THE TANK LIVES!
4DMR2t's Avatar
View 4DMR2t's Photo Gallery
You can probably get away with adjusting it a couple times, but you're only delaying the inevitable.
your cables are getting stretched and they eventually will snap if you keep stretching em. Better look into investing in new cables.
And if you have the dough, it's best to replace all 3 at the same time, to avoid having to get under the car numerous times. It's a pain in the ass working around the fuel tank.
"It's hard to drive at your limit, but it's harder to know where it is." -Sterling Moss
4DMR2t is offline   Reply With Quote
Old 10-13-2005, 03:28 PM   #9 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
3 cables? are they in a set or do they have to be purchused separately? I'm guessing the main cable from the handle and the other 2 going to each rear wheel?
Old 10-13-2005, 06:12 PM   #10 (permalink)
4DMR2t's Avatar
when i replaced mine, they came seperately. And, there aren't really any aftermarket companies that make em, so you're stuck buying em from toyota or partznet.
The partznet prices are better than your local dealer.
The front cable is around $25 and the 2 rear cables are about $60 a piece, but you can probably find em a little cheaper if you search around.
Old 10-13-2005, 09:43 PM   #11 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
holy crap! they're proud of those cables huh? ...it barely grabs now. i wouldn't trust it on a hill .. so got no choice... thanks, gonna be my next fix
Old 10-18-2005, 11:28 AM   #12 (permalink)
View thetailwind's Photo Gallery
I replaced mine also. you cant go wrong with rockauto.com the prices are good there and I got my cables rather quick. Its an easy fix after you get all that plastic crap off of the bottom. it should take under an hour to fix.
thetailwind is offline   Reply With Quote
Old 10-18-2005, 12:39 PM   #13 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
thanks, do you remember how much u paid for them with shipping?
