Clutch for 5SFTE? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-14-2005, 11:01 AM   #1 (permalink)
View Mister-Twoster's Photo Gallery
Clutch for 5SFTE?
I need a clutch that will handle my 5SFTE conversion. It should be putting out about 160-200hp depending on how many corners i cut Anyways, what clutch will handle the new power the best? Oh yea, this is going in a 91.
Mister-Twoster is offline   Reply With Quote
Old 10-15-2005, 10:41 PM   #2 (permalink)
_ _ _ _ _
View asifmbadar's Photo Gallery
How much power does the stock piece hold?
asifmbadar is offline   Reply With Quote
Old 10-16-2005, 01:36 PM   #3 (permalink)
Now with even more BOOST
View QuadCamSix's Photo Gallery
What are your power goals because the centerforce stage 1 should handle 200ft/lbs just fine.
MR2 V6 with an inordinate ammount of boost www.V6MR2.com
QuadCamSix is offline   Reply With Quote
Old 10-16-2005, 06:49 PM   #4 (permalink)
I wont have more than 200rwhp... probably no more than 180. I have been told stage 1 shoudl be able to do it as well, along with stock even.
Old 10-18-2005, 01:43 PM   #5 (permalink)
kouki ae86
stealthtrueno's Avatar
View stealthtrueno's Photo Gallery
$165 discount auto parts. should hold that power just fine.
AE86 FTW!
stealthtrueno is offline   Reply With Quote
Old 10-20-2005, 12:52 AM   #6 (permalink)
I agree but if you plan on autocrossing or driving really hard get the next stage up so it will handle the heat better. I use up clutches quickly just because of my driving style so I always upgrade when they need work. You could get an upgraded disk with a stock pressure plate. That way the material would handle hard launches better but the peddal effort would be the same.
Old 10-20-2005, 01:15 AM   #7 (permalink)
FRANK THE TANK LIVES!
4DMR2t's Avatar
View 4DMR2t's Photo Gallery
which tranny are you using?
"It's hard to drive at your limit, but it's harder to know where it is." -Sterling Moss
4DMR2t is offline   Reply With Quote
Old 10-20-2005, 04:09 AM   #8 (permalink)
The Other White Meat
terrastrife's Avatar
lol i was wondeirng when someone would ask this
terrastrife is offline   Reply With Quote
