Originally Posted by Ironmike4x4
I've found that Iridiums perform much better for most Toyotas, not too sure about the cars. The 4Runners and Tacomas are very picky about spark plugs and wires. Usually it's highly recommended on several forums to run Denso or NGK
ok, but can you explain how they are? i mean, i have done EXTENSIVE research with spark plugs. i bought about $200.00USD worth of just about every plug i could get my hands on...had a stretch of road and a Vericom computer to measure 'performance'...found NO diffierence in 'performance'...all done with laboratory-like precision and kept same parameters. then i did all of the tests with another car. NO CHANGES.
Denso doesn't seem to have a good heat range selection here in the U.S. but i'll bet they might in Japan. that's the only reason i tend to use NGK for my cars. everything else uses stock heat ranges for plugs.
BTW: BCPR7ES-11 is an NGK plug.
and i have 7 Toyotas...van, trucks, cars, SUV...
