Power Antenna Issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-20-2005, 03:49 PM   #1 (permalink)
View semi-charmed's Photo Gallery
2nd Generation Power Antenna Issue
when i bought my car the power antenna wasn't working...but a friend of mine told me it was more than likely just the antenna mast that was the problem...i figured he was right because i could hear the antenna motor working when i shut of the car...at least i think it's the power antenna motor...anyway...i get the mast from toyota, which cost me about $44 CAD and i open up the assembly only to find the the two spool gears (the ones that essentially push and pull the antenna up and down) are missing!
as far as i can tell everything else is working fine, i just need those two gears...does anyone know if i would be able to get those off of any standard toyota? or does anyone have some of them kicking around? i went to the dealership and they wanted to charge me almost $300 for the entire assembly unit...thanks in advance guys
semi-charmed is offline   Reply With Quote
Old 10-20-2005, 06:00 PM   #2 (permalink)
FRANK THE TANK LIVES!
4DMR2t's Avatar
View 4DMR2t's Photo Gallery
the only thing I can tell you is maybe check a couple junk yards.
The MR2OC "parts for sale" forum wouldn't be a bad place to check either.
Good luck!
"It's hard to drive at your limit, but it's harder to know where it is." -Sterling Moss
4DMR2t is offline   Reply With Quote
Old 10-20-2005, 06:08 PM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
yeah, do the scrap yard thing or I've sen the whole assembly-motor and mast -on Ebay for $25.00...
The Jedi Speeder at CarDomain
Old 10-20-2005, 06:50 PM   #4 (permalink)
View carcatz's Photo Gallery
are you sure its the gears and not just the mast?
carcatz is offline   Reply With Quote
Old 10-20-2005, 07:18 PM   #5 (permalink)
yeah i was gonna hit a junk yard this weekend...i was just wondering if anyone knew if i could use the gears off of a corolla or whatever...and yes carcatz, it is the gears cause they're physically missing
i just can't believe someone would open up the antenna and take out the two gears and then seal it up like nothing...geez
Old 10-20-2005, 08:02 PM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
maybe they just fell off. or someone else needed the gears. anyway, just see if the gears you're talkin' about mesh and fit...i think most are pretty much the same..nothing to lose..it's worth a try..maybe save some money
Old 10-21-2005, 09:44 AM   #7 (permalink)
helpful
View lioneljones2001's Photo Gallery
buy 1 from ebay for 30 dollars. i did over a year ago and mine still works fine
lioneljones2001 is offline   Reply With Quote
Old 10-21-2005, 06:47 PM   #8 (permalink)
_ _ _ _ _
View asifmbadar's Photo Gallery
Buy it off eBay and call it a day That's a common problem for not just MR2's but a lot of other cars that have a power antenna.
asifmbadar is offline   Reply With Quote
Old 06-19-2006, 09:19 PM   #9 (permalink)
okay i replaced the mast last year and the antenna worked like clockwork for the last couple months...now however, it goes up fine but doesn't want to come down...it will go down if you help the motor a bit by pushing it with your hand...but it won't do it on its on...i took apart the motor assembly and realized that the mast was in perfect condition, but the plastic gears were slipping and grinding...i just found it odd that it doesn't have any problem going up, but it slips when going down...has anyone come across this problem before?
i assume that if the gears are too worn down i will have to buy an entirely new assembly...i found a couple on ebay but none of them are for an MK2 MR2 WITH a spoiler...the dealer quoted me at over 200 for the assembly...if no one can help me fix this, does anyone have one they can sell me?
-Ryan
Project Turbo Two
